How to calculate check valve pressure drop for 2 phase flow (lig/gas)?
Can anyone point me in the right direction? I need an accurate method. Thanks.
RE: How to calculate check valve pressure drop for 2 phase flow (lig/gas)?
To get started, I'd suggest the latest edition of Perry's for the basics. For relief work, we use the Homogeneous Equilibrium Model where I work.
Good luck,
Latexman
Power, Aug. 1976, pp.25-36, "Check Valves", W.O'Keefe
ASCE Proc. V102, Jan.-July 1970, 57-72, Kane & Cho
Handbook of Hydraulic Resistance, 2nd Ed. 1986, Diagram 9-21, Idelchik
Let's say you use the homogeneous equilibrium model and it estimates the dP = 18 psi. For 95% confidence limits on the *actual* dP, the lower limit = 18/1.8 = 10 psi and the upper limit = 18x1.8 = 32 psi. So, you can be 95% confident the actual dP is going to be between 10 to 32 psi. Not too accurate, huh?
Good luck,
Latexman
