abaqus instruction check
Hi everyone,
i need help.
i use 6.3.1 on win2000, and i want to check if after running job, loads and constraints i gave to the model are correct (i usually write an .inp file).
how to do it in viewer?
does anyone know if "abaqus post" works with abaqus 6.3.1?
i tried also to check the file importing .inp and .fil with femap 8.2 but may be it has problems with the following line command
*NCOPY,CHANGE NUMBER=286,OLD SET=SYMM1,SHIFT,MULTIPLE=10,NEW SET=TOTAL
0.,0.,0.
0.,0.,0.,0.,0.,1.,18.
bye and thanks in advance.
fabio
i need help.
0.,0.,0.
fabio
RE: abaqus instruction check
abaqus job=<jobname> datacheck interactive
if no problems are found, then you can continue on with the analysis using:
abaqus job=<jobname> continue interactive
The above assumes your are running on a UNIX (e.g. HP-UX) platform, but running through a DOS prompt the syntax should be very similar.
The best of luck,
-- drej --
corus
http://www.corusresearch.com
