Chassis/Body Roll Inertia values
Im after a more accurate roll inertia value for medium sized sedan style cars (around the 1200 - 1600kg mark). I have a value for formula style cars at 140 kg.m^2 (3300lb.ft^2) although im guessing this is much too low to apply to road cars. Anyone have any more accurate ball park figuers?
Jake
Jake
RE: Chassis/Body Roll Inertia values
Front ground reaction N 9070.49
Rear ground reaction N 7023.69
Total roll inertia Kg mm**2 550.4E+06
Total pitch inertia Kg mm**2 3.617E+09
Total yaw inertia Kg mm**2 3.532E+09
Total product Ixy Kg mm**2 -1.005E+06
Total product Ixz Kg mm**2 -30.32E+06
Total product Iyz Kg mm**2 4.843E+06
for an anonymous car
Cheers
Greg Locock
Jake
SAE 1999-01-1336 Measured Vehicle Inertial Parameters - NHTSA's Data through November 1998
Gary J. Heydinger - Sea Inc., W. Riley Garrott - NHTSA
http://www-nrd.nhtsa.dot.gov/vrtc/ca/capubs/sae1999-01-...
Other publications from SAE International (www.sae.org) that may be of interest are:
2001-01-0475 Test Method for Simulating Vehicle Rollover
Mike Rossey - Autoliv
www.sae.org/servlets/productDetail?PROD_TYP=PAPER&PROD_...
2003-01-0966 Estimation of Passenger Vehicle Inertial Properties and Their Effect on Stability and Handling
R. Wade Allen ,David H. Klyde, Theodore J. Rosenthal; Systems Technology Inc.
http://www.sae.org/servlets/productDetail?PROD_TYP=PAPE...
Best regards,
Matthew Ian Loew
"Luck is the residue of design."
Branch Rickey
