DIalog box/command line problem
i have MDT 4 & i can t see some Dialog box when i choose EXTRUDE, SWEEP, REVOLVE profile & etc. Options for this commnad put in command line? what can i do to get dialog box option again?
RE: DIalog box/command line problem
type: cmddia
and set it from "0" to "1"
you should see the dialog boxes now
Also you might want to check filedia and set it from 0 to 1 if needed.
Linqur
I keep on having 2 problems:
- I lose the dialog boxes and the commands cmddia and filedia do not solve the problem.
- In some cases (for instance at placing balloons) I cannot see my mouse cursor in the screen when MD asks me to select. The cursor is visible in the command line and the pull down menu, but not in the screen.
Does anyone know how to solve these problems?
Ron
how about updating your video display driver
