High Pressure Small Diameter Jacketed SS Piping
Does anyone have experience or design know-how for fabrication and joint design with high pressure (5000 psig) small diameter (3/8" - 3/4") stainless steel jacketed pipe or tubing to maintain a core temperature of 85-90 deg C ?
Do you know of a vendor that supplies such piping systems, including the heating fluid system?
RE: High Pressure Small Diameter Jacketed SS Piping
Though we fabricated most of our own jacketed pipe we did use the following company for some fabrications.  they can help you with the heating also.
http://www.csiheat.com
