Roland Pen Plotters
Roland Pen Plotters
Roland Pen Plotters
I have a Roland GRX-400 pen plotter. This plotter works fine under R14 as Roland produced an ADI Driver for R14 but, they aren't producing one for r2000 on. Their advice is to use a hp7580 driver but, this is only capable of producing dwg's to A1 and no bigger and the Roland can print upto A0. Can anyone out there help with a solution to this problem?
RE: Roland Pen Plotters
well if the roland you have uses HP/gl then you can use any of the drivers from hp that are pen plotters they were probably refering you to the hp7580 because its the one most compatable to it look in your manual for your roland and see what languages it reads (plotter language)
if everyone helps everybody the world will be a better place
