assembly of bearing
assembly of bearing
Hi All,
I have the peculiar doubt, can a bearing be fitted into a housing where the housing surface is not ground but is spark eroded? to reframe it, if the OD tolerance be maintained but the surface roughness maintained to that obtained from a spark (EDM) but not a ground finish, can it still be an appropriate assembly. The product I'm talking about has high tolerances on endplay and radial play.
Thankyou very much,
Lalitha
Thankyou very much,
Lalitha
RE: assembly of bearing
MadMango
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Do you want to plunge EDM a blind hole for the bearing or wire EDM a through hole for the bearing? Based on my experience the wire process can be controlled better than the plunge unit but there has to be a start hole fashioned somehow.
The wire process can attain very good bore tolerance, in the hands of a good machine and experienced operator, sufficient to mate with the outside of the outer race of a bearing, particularly if the bore length to bore diameter is < 1.
Plunge EDM'ing may require multiple setups to get a perfect blind hole cylinder with square shoulder.
We are still working on the different layouts, and would do a cost & Effect analysis to opt for the best alternative. Appreciate your help and thankyou once again.
