Inserting and Positioning a Part into a Part
I have successfully been able to insert a part into another part but have trouble positioning it.  I can either rotate it or translate it but not both.  Is there any trick to this?
RE: Inserting and Positioning a Part into a Part
You should be able to freely rotate the part in all directions before you apply any mates.
Look at positioning via Distance Mates between planes.
MadMango
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Thanks for the reply.  I am not talking about assembly mates.  I am talking about inserting a part into another part file for use as a tool body for making a "combine" cut or whatever the correct term is.
Have you tried "Base Part"?
Ken
Sounds like you almost want to cut and paste a solid from another file and then combine them??
(I'm trying to understand your intent) If I'm on track, someone else will have to respond with the cut and paste 'how-to' - provided it can be done (as for me, I haven't gotten to that chapter yet
Base part?  I guess I haven't tried that.  I'll give it a look.
I am able to insert a part in to another part file by going to the "Insert" drop down menu and selecting "Part".  From there, I can rotate the part by entering values, or I can move it by selecting points, but I can only do one or the other.  Seems pretty odd to me.  Must be something simple I am overlooking.
I misunderstood the question.  Base Part won't allow you to move/rotate the inserted part either.
Ken
You insert your part (Insert / Part) then you can use the check box in that option to launch the Move / Copy Body functionality.  You can simply move, then rotate in 2 steps.  To get back to the Move / Copy, you go to Insert / Features / (Move/Copy)
Hope that is what you were looking for
Daniel
