Looking for a Latching Solid State Relay
Can anyone point me in the direction of a Solid State Relay equivalent to an:
       SSAC  NIF1B6A4
       Latching, Solid State
       6A, 120VAC Output
       120V Control Voltage
Our supplier dropped the ball, so I'm looking for a substitute to this relay.  So far, my local suppliers are no go.
Any help would be greatly appreciated.
Thanks!
Tef
RE: Looking for a Latching Solid State Relay
Connect an optocoupler's LED with diode bridge and series resistor to the switched AC, connect the transistor to
energize the SSR input.
If need more help, describe the driver on the input of SSR
and give URL & FAX#.
<nbucska@pcperipherals.com>
You should find what you are looking for on www.Crydom.com.
Suggestion: Visit
http://www.thomasregister.com
and type Relays: Solid State under Product or Service, which will return 140 companies to approach to
Thanks for the info all.  We're just going to wait for the part.  No one had anything in stock.  "Just In Time" manufacturing seems to equal "Just In Time To Miss Deadlines", anymore.  Oh well.
Tef
There is a simple alternative -- move the latching to lower power level.
Suggestion to the previous posting: If possible.
