change element size in Integrated Mode
Hi all,
I am a new user of Pro/MECHANICA, and I am wondering how to control elements size in Integrated Mode when you mesh the model.
Thanks in advance!
Anny
Thanks in advance!
Anny
RE: change element size in Integrated Mode
If you are a maintenance paying customer, a great source of information is the PTC "Knowledge Base". Look under the Support Tools heading on:
www.ptc.com/support/support.htm
There is recommended practice detailed on the site. To summarize, you need to introduce geometry that forces elements to be created at certain features. The recommended practice is to use surface regions and/or volume regions although using curve features and points created in Pro/MECHANICA can work as well.
The link to the Knowledge Base is in the FAQ Pro/MECHANICA internet resources (FAQ828-702).
Best regards,
Matthew Ian Loew
"Luck is the residue of design."
Branch Rickey
Thank you so much! The info is very helpful.
Anny
