Redefining pattern options in Wildfire
How do I redefine pattern options in Wildfire from the failed feature menu?
RE: Redefining pattern options in Wildfire
If you have overlapping geometry in your pattern you will have to use a General pattern option. This might be your problem? Just change the pattern type to General and see if that resolves the feature?
If the leader of the pattern has failed causing the pattern to fail you have to correct the leader before the pattern can be corrected. Again I would select redefine to resolve the leader.
If this doesn't work then I would use "clip suppress" and browse the model tree to see which feature is causing the problem. The clip suppress function will suppress everything below (including) the failed feature.
Does this help?
Does this make sense?
