Hi, Can anyone tell me if WLR colu
Can anyone tell me if WLR column is supposed to leak at the flanges? I would presume not, but I have reason to believe that leaks have occured on several of our jobs. Is there a way to prevent leaking at the 8" column flanges? We have tried wire brushing the mating surfaces to remove any debris, and have tried re-assembly with and without silicone with the same undesirable results.
If there is not a good way to stop the leaking, is there any rule of thumb to calculate the loss in volume?
Thank you
Rainman55
Thank you
Rainman55
RE: Hi, Can anyone tell me if WLR colu
We make some of there brass packing glands
