Tube with built in mounting flange?
Does anyone know of a manufacturer that produces tubing (stainless steel or aluminum) with an integral mount flange, i.e. a flat piece that extends the length of the tube and not perpindicular with the fluid flow? Something like this _O_ .
And a technical question, for a 3/8" tube is it better to have 2 2" bends with ~1" straight section or 1 4" bend?
Jennifer
RE: Tube with built in mounting flange?
I would go with 4" as it is easier to make and the pressure drop will be less given your information.
You din't say what quanity of the tubing need. I don't have any people with anything approcahing your cross section.
If it's not a large quanity you might try on of these companies.
http://www.extrusions-ez.com/extrusions/0030055_0069563...
