As-Builts and Archiving Project Data
I'm interested in knowing what method or strategy people are employing for their projects as-built documentation and handover packages. I've been briefed by various people about keeping it all in hardcopy and others produce hardcopy and have an external supplier create digitial copies for actual handover. Still others create a massive amount of documents electronically but, in varying formats. I'm looking for something easy to use and extremely easy to retrieve final information from later on. All comments welcome.
RE: As-Builts and Archiving Project Data
Would Adobe Acrobat work sufficiently well for you to generate your packages?  If so, you could assemble everything into a .pdf file for handoff.
We keep hardcopies of all drawings, including revisions as well as correspondence.  In addition, we keep digital copies of all documents (including *.pdf's made of documents).
Typical file number for drawings is yynnnt01.dwm, where yy is the year, nnn is the 3 digit project number, t is the discipline (A, S, M, etc.) and m is the revision number (0-9) as well as *.dwg which is the current AutoCAD drawing.  Drawing numbering differs substantially from the 'standard' and we use it for consistency with earlier projects.
For documents other than drawings we have a fairly elaborate nameing system depending on the type of correspondence.  For example 03-128e.r04.doc would be project 03-128, an engineering report, number 4 in sequence (preceeded by 1-3); correspondence 03-128.l08.doc would be the same project but would be a letter (l), the 8th in a sequence... 03128s03.dw2 would be the second revision to structural drawing s03 for project 03-128... and so forth... as below for correspondence types...
CORRESPONDENCE EXTENSIONS
ADDENDA                    filename.Ann
ASCII TEXT            filename.Tnn
ARCHITECTURAL REPORTS    filenameA.Rnn
BID FORM                filename.TSn
CERTIFICATE OF PAYMENTS    filenameC.Cnn
SUBSTANTIAL COMPLETION    filenameC.SC1
CHANGE ORDERS       filename.Onn
CONCRETE TESTS            filenameCT.Rnn
CONFERENCE REPORTS    filenameC.Rnn
AGENDA              filenameC.Ann
CCO'S               filename.Cnn
DOCUMENTS            filename.Dnn
ENGINEERING REPORTS    filenameE.Rnn
EXCEL SPREADSHEETS
    ESTIMATES    filenameX.Enn
    CO SUMMARY    filenameX.Cnn
    CA SUMMARY    filenameX.Ann
    TENDER SUMMARY    filenameX.Tnn
ESWO                filename.Enn
FEE PROPOSALS            filename.Fnn
INVOICES            filename.Inn
JOB SITE INSTRUCTIONS    filename.Jnn
LETTERS                    filename.Lnn
MATHCAD DESIGN FILES    fnameDnn.MCD
MEMORANDA            filename.Mnn
OWNER CONTRACT         filename.OC
PROJECT MEETING REPORTS    filenameM.Rnn
PHOTO COLLECTION    filename.PHn
PHOTOGRAPHS            fnamePnn.TIF
REPORT                    filenameR.Rnn
REPORT SUMMARY            filenameS.Rnn
SCANNED IMAGES            fnameSnn.TIF
SCHEDULES               filenameS.Nnn
SHORT FORM CONTRACT    filename.GCn
SITE VISIT REPORTS    filenameE.Rnn
STATEMENTS            filename.Snn
TENDER DOCUMENTS    filenameT.Tnn
where filename has the format  yy-num, and
fname has the format yynum
One caveat, if you're keeping digital copies of drawings in the their native format from the CAD system, you'll need to archive a copy of that software.  In many cases, updated CAD software requires conversions, which you might not have budget for, so keeping copies of the software potentially ensures future access to drawings in their native formats.
TTFN
I don’t like handing over documents in their native formats.
I will hand over everything in PDF format. For file names I use the long file names built into Windows and give the document a very descriptive file name. I organize them into folders in the same way that I would have them in physical file folders.
The advantage is that you cannot modify a document in PDF (at least not without some knowledge and a lot of time) but a native format document can be easily modified.
The main exception to this is dwg files. There are a lot of legitimate needs for these to be passed around. For example in municipal sub division design the gas and electric companies want copies so that they do not have to re-draft the basic layout. The city needs them for their composite as built records.
In these I am always careful to remove any electronic copies of my seal and to include a copyright notice stating that I retain copyright but am granting this limited copyright to the utility for the sole purpose of their involvement in this project. I also shrink this to dot size and leave it scattered around the drawing.
Rick Kitson MBA P.Eng
Construction Project Management
From conception to completion
www.kitsonengineering.com
Thank you for the quick responses. Obviously PDF seems to be the agreed upon format. I know that acrobat reader is free so it makes the handover side of things easy enough but, having alot of documentation to get through do I try to outsource the conversions or bring in temps to do the scanning and indexing of the files? If I should be outsourcing and quality and retrieval are the most important parts of finished product would anyone know a good company in the UK to go to? I have done some research on numbers and there are quite a few companies claiming to do this sort of work, where do I go? If I bring in temps any idea how much the equipment and software are going to cost me?
Another good reason to keep up with the scanning and archiving as the project progresses.
I try to never get more than one week behind.
If somone had to turn any manual or a catalogue to you, try to clearly mark or ask the supplier to mark which particular model is being used. Later,  when you need to order  spare parts you would know which model you have.
