Standard? - Tolerances on Injection molded parts
Thanks again for your help on question #1.
Question #2 -
Which US Standard covers general "working" tolerances specifically for injection molded plastic parts?
Thanks.
Matthias, the German
Question #2 -
Thanks.
RE: Standard? - Tolerances on Injection molded parts
As for 'tolerance', you may find that many dimensions on a drawing (especially for a large part) may require +/- tolerances added as the total tolerance zone for larger pieces can often exceed what is indicated in a standard drawing tolerance block.
