Simatic Cables
Simatic Cables
Simatic Cables
I am looking for information on different cables and connections used to connect Siemens PLC to OP's and PG's.
Are all the connections to OP's the same?
Is there a manual/data sheet available to download showing all connections?
Thanks.
RE: Simatic Cables
Yes.. Siemens has a manual that covers pinouts for connection to the different devices. I think that it's called KomWin_e.pdf or something like that. I think that it comes with the standard documentation library. Email me if you can't find it and I'll send it to you. I also have a "pinout spreadsheet" that I can send you if you want it.
email (remove spaces and replace AT with @)- mikell AT cvtv.net.
