propane requirements for a turbo big block
I have studied the Impco catalogs for info on 425 mixers and found that they will flow around 460cfm and are good to about 300hp. My question is, on a turbocharged big block V8 capable of 700+hp would you require more than 2 of these mixers to adequately fuel this engine? I'm thinking along the lines of 3 mixers. Thanks.
Tom
Tom
RE: propane requirements for a turbo big block
Franz
