Animal Shelter Sewerage System Design
I am currently working on a sewerage system design for an Animal Shelter, the local sewer authority will not allow us to discharge the "stuff" in there sytem the BOD and TSS are really >400mg/l and 153 mg/l respectively. The shelter will have 37 kennels. Any ideas on how to treat the effluent?
Jason McConnell
Jason McConnell
RE: Animal Shelter Sewerage System Design
Dog kennel - outside runs
Thread161-67075
Do a search for " " and you will find it.
You should also put an effluent screen (i.e. Zabel or PolyLok) at the outlet of your septic tank(s).
You also need to review and limit what is used for any grooming operations on-site (i.e. flea/tick shampoos etc.) as some are not suitable for subsurface disposal.
What is the BOD loading rate for a dog? Nitrogen loading rate per dog?
The hope of the contractor is to construct a lagoon. Local officials don't want the lagoon to discharge. No POTW is reasonibly close enough to connect.
Any help is appriciated.
other quesitons:
Is the connection of the wash basin to the lagoon a problem due to shampoos or drugs?
Thanks for your suggestions.
