Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I am very happy with the whole site and would like to extend my compliments to all of you who work to make it one of the most useful sites (If not THE Most Useful) ...and the easiest to navigate..."
Geography
Attaching plexiglas windshield to composite fuselage
Mgundwane (Aeronautics)
7 Nov 03 10:56
Dear ladies and gentlemen
Could somebody out there give me some details on how to actually fix (bond and clamp or just bond) a 5mm thick plexiglass windshield (simmilar shape and size as the EC135 windshields) to a composite fuselage structure of a two bladed helicopter.
1. What needs to be considered in terms of possible fuselage oscilations and the effect on the bonding/sealer?
2. Would a mechanical clamping in addition to a 5mm thick  flexible sealer/bonding layer be of any advantage?
How do the professional manufacturers do it?
Thank you in advance.
Thys Pieterse
gyromaxwell (Aeronautics)
17 Nov 03 7:52
The method that I have seen used many times is as follows:
a rubber grommet of a given dia. is used in a hole that is larger then the fastening screw. the grommet thickness is greater then the windshield thickness and/or over-laps the windshield. the screw is then passed thru the windshield hole and thru the composite hole. a nylock nut is then placed on the screw. using flathead screws keeps the outer surface smooth.
Hope this helps!
Tim Blackwell
Gyro-designer
aviat (Aerospace)
18 Nov 03 21:36
You can try this site and then contact them for more info it necessary.
http://members.eaa.org/home/homebuilders/authors/bingel...
Close Box
Join Eng-Tips® Today!
Join Us             Close
