How to Draw a Perpendicular Line to the end of another line
Dear all,
Could somebody please advise how to draw a perpendicular and have it snap to the end of another line? I can draw a perpendicular line with the "perp" (is there another way to draw a perpendicular line, icon, perhaps?) but it snaps to somewhere along the line and not at the end. Thanks.
RE: How to Draw a Perpendicular Line to the end of another line
and this will you a perpendicular line.
(DEFUN C:AE (/ osm otm sa a) ; Set snap angle using endpoints
(setq osm (getvar "osmode")
otm (getvar "orthomode")
sa (getvar "snapangle")
(setvar "osmode" 1)
(setvar "orthomode" 1)
(setq a (getangle "\nSelect line ENDpoints to set new SNAP angle: "))
(setvar "snapang" a)
(command "line" pause pause "")
(setvar "osmode" osm)
(setvar "orthomode" otm)
(setvar "snapang" sa)
(PRINC)
Flores
sa (getvar "snapang")
(setvar "osmode" 1)
(PRINC)
Surprisingly, ACAD changed the variable "snapang" even though the original code was mispelled "snapangLE".
Flores
I use "_ucs"-> _object -> click the line -> "_line" -> snap the endpoint -> and draw the line (Don't forget "F8")
Lothar
Pardal
Try this lisp:
; RITEANG.LSP
; Description: create a line 90 degrees anywhere along an existing line.
(prompt "\nType RA2 to run.")(graphscr)(princ)
(defun C:RA2(/ P1 P2)
(setq OMODE(getvar "ORTHOMODE"))
(setq SANG (getvar "SNAPANG"))
(setvar "OSMODE" 512)
(setq P1 (getpoint "\nPick a point on the existing line for the start of the new line."))
(setq P2 (getpoint "\nPick a second point on the existing line."))
(prompt "\nPick a point for the end of the new line.")
(setvar "ORTHOMODE" 1); ortho on
(setvar "SNAPANG" (+(angle P2 P1)(/ pi 2)) ); set snapang to angle of line
(command "line" P1 pause ""); draw the line
(setvar "ORTHOMODE" OMODE)
(setvar "SNAPANG" SANG)
(princ)
); End of Program
In Mechanical Desktop there is a simpler method: type AMCOPYRM, then pick the line in the snap point wanted, answer yes to copy prompt and enter 90 (degrees) or the angle you want.
Explore AMCOPYRM, is a great order.
If you does not have Mec desktop, there are Lisp programs that do the same the order does.
Try Google or write a request.
Excuse my english.
Xan.
Then use move "end" point of new line at intersection to "end" point of original line.
Unless I am missing something?
Grip the line
Hot grip the endpoint of the line
Space
Space (For rotate)
C (for copy)
90 or -90
Esc
Esc (to get out of grip)
(defun c:1 ()(command "ucs" "ob"))
It sets the '1' as a command for the ucs<object like Exxit's explanation.
It is quick and I use this command constantly having to deal with roof pitches (3:12, etc.) The end of the object you select that is closest, will become the origin and the x-axis will align down the part.
Start drawing the line from the other end? i.e. Make sure you have a running OSNAP set to (at least) endpoint, and voila - no programming required.
I MUST be missing something, or it would not seem this trivial...
The lines are not necessarily oriented with the UCS.
IN that case, some of the above answers (not involving programming) would be my choice. Another option, is to temporarily re-orient the UCS and use F8 (ortho).
Oops...
