Survey camera stuck up pipe. HELP
Can anyone give a decent answer on how to remove a CCTV camera that has broken down inside a sewer pipe. Its approx 60m in. Its wheel driven, so is a dead weight to pull and it may be jammed up. The control cable attachment is weak, so I don't want to pull it out using that.
Does anyone have any ideas.
tia
tia
RE: Survey camera stuck up pipe. HELP
If you have more time, perhaps sending another camera (with a stronger retreival cable) to determine the problem would be a possibility? I have heard of folks using a jetter to pull a chain/cable past the camera to the next manhole, attaching a hook, etc and pulling it back through, but I wouldn't try that unless you know what's obstructing it.
"If a camera becomes jammed in a sewer and cannot be pulled out, the "Owner" will recover the camera by excavation where economically justified at no cost to the Contractor. The Contractor shall insure the camera against total loss or damage.
KRS Services
www.krs-services.com
