Re-appearing text in dimension
Here is one I cannot say I have seen discussed out here (although I do not always get to read every post). Today I was called to help an associate who was having a problem. We are running SW2003 SP4.0. He was trying to finish detail someone else had started. The hole dimension in question was put in using hole callout. Because the hole (not made with hole wizard) was put in using the through all option, hole callout added the word thru to the dimension. He did want thru in the callout so he edited the dimension and removed it. When he printed the drawing, the thru would magically re-appear. He edited the dimension several times, saved the drawing, and even exited out of SW then re-opened the drawing, printed and the thru re-appearred. When I came over to help, I had him open the model and look at how the feature was modeled. Nothing looked out of the ordinary so I had him go back to the drawing and edit out the thru again. This time when he printed the thru did not re-appear. Unfortunately, he saved so we now cannot duplicate the problem. Any suggestions on what caused this or should I just chalk it up to one the those mysterious bugs that show up now and then?
RE: Re-appearing text in dimension
Good luck!
***Back it up First ***
Have you tried SP5.0 for SW03? Maybe there is a fix in there if it was a bug.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check th
I cannot upgrade to SP 5.0 without premission. I suppose I could have sent it off to our VAR, they keep several versions of SW on hand, but now that I cannot repeat the bug, it would not make any difference anyway.
All I was really looking for was if anyone else had seen this problem.
