Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Praise should be given to the Forum managers or the Tipmasters - they are what make it work - give them extra recognition!!! They are timely (prompt - unlike ACTUAL support sites) and on the ball!!!..."
Geography
nedians (Civil/Environmental)
11 Jun 01 13:36
  Kindly help me on the following:
1) If i have the wind data for daytime visual meteorological conditions, what steps should i flow in order to draw a wind rose diagram and then finding the orientation of runway(assuming magnetic north to be 10 degrees ).
2) Is there any free downloadable software which i can use to complete this project or can i use excel spread sheet for this.?
3) Is there any website related to this, which can provide the Basic information ?
4) If i want to make a Electronic Model for this can i do that?
georam (Geotechnical)
12 Jun 01 13:53
I suggest that you should read one of the chapter on Airport configuration from the well known text book by R. Horonjeff , "Planning and design of airports". A portion of this chapter deals with the wind rose, and some examples.
I also assume that FAA and ICAO guidelines provide some info on the selection of the runway from wind rose diagram.
As far as using a software to create wind rose, try
http://www.windpower.dk/tour/wres/roseplot.htm
12 Jun 01 14:07
In addition :
If you do not have access to the textbook, you may download airport related document from USACE
http://www.usace.army.mil/inet/usace-docs/armytm/
Select TM 5-803-7   Technical Manual on Airport and Heliport Planning Criteria.
Attachement 5 discusses about the use of wind rose, with charts, etc.  Good and comprehensive chapter to read.
Hope this helps you along
Farhan1 (Civil/Environmental)
7 Jan 02 14:39
hi
I need the diagrams & complete procedure of WIND ROSE method
in selecting runway direction
regards
Close Box
Join Eng-Tips® Today!
Join Us             Close
