Metallic compound (Hi-temp Lab metal)
Hi guys,
I would like to know from past experiences if anybody has succeed in fixing a non-pressure retaining part on a vessel working at high temp. as 510°F on steam (i.e. baffle plate or something like) with a product like Hi-temp Lab Metal from Alvin products?
Or maybe you have experienced with other similar product?
Marc
Marc
RE: Metallic compound (Hi-temp Lab metal)
Most of these work by forming an Al rich alloy(mixture) with Zinc or a Zinc matrix with Al particles.
They have there places, but not in a steam chest
DO you had any bad experiences or know peoples who had bad experiences with this kind of product on steam, I'm asking because the product manufacturer assume that it do the job on steam ?
There is a material of similar description and makeup that cost my company many thousands of dollars when used to "repair" the channel section of a heat exchanger. Also a different product of the same type caused outages in a 175# steam system when used to fill in very large tube sheet.
Unless there has been drastic improvements in these type materials they are not suitable for you temperatures. Even Aluminum metal’s strength starts to fall off rapidly at these temperatures.
