from autocad to position
is it possible to have coordinates off a "drillingpoint or a point in a drawing whith autocad so I can control my position ?
RE: from autocad to position
AutoCAD has programming capability through its Application Programming Interface (API).  Typically this is programmed in the AutoCAD LISP language, or VB, or C++.
From that, you have the capability to extract positional data from a AutoCAD.  The important thing is that you must calibrate your CAD object with your robot coordinate system.  The same type of thing is done all of the time for 2D laser cutting applications and is available on the market from a variety of sources.
For 3D work, you can check out www.robotworks-eu.com, they have something that works with SolidWorks.
Email is a stealth email to minimize spam.  Contact me & I'll get back in touch with you.
TygerDawg
