Alternate Field
Alternate Field
Hi! I need to get the alternate B field of my program. For this, I have thought to make the difference between two static fields and then have the alternate field. In ANSYS, one possibility is create an ARRAY with the element reference (X,Y & Z components) and its value (for example MMF, altough the analisys is static, then B=rotA) so i have the B array for the first step. I make the same for the second one; i have the output array and i export it to MATLAB; i make the difference between them and... do you think that is possible to have the alternate field??? Do you know another way ?? Thanks
