additions in dimensions value is not accepting
Dear all
If I want to change the dimension by editing in sketch it is not accepting.I mean if I want to increase or decrese the value of 2.1345345 by .5 in this way
2.134534+.5
 it is not accepting.I hope for this some where any setting has to change.If any one knows please let me know
Thanks and Regards
Reswam
RE: additions in dimensions value is not accepting
The problem is in your VBA. it sounds like it wasn't installed correctly.
If your using SW03 Follow below
Try this for reinstalling the VBA in SW03:
Windows Installer:
Uninstall and reisntall SW per FAQ559-488
Traditional or Install shield:
1) Go to SW install folder on your Hard drive
2) Go to VBA Folder and RMB the vba6.msi and click uninstall
3) Go to CD 1 sw\vba\vba6.msi and install that file.
If your using SW04 then you will have to reinstall.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
Thank you Sbaugh
