Equilibrium curve for butane-propane
hi,
i'm trying to design a distillation column which will separate propane from butane (at 18 atm) and i'm looking for the equilibrium curve for the mixture butane-propne... i didn't find it.
can someone send it to me please ?
thanks a lot.
thanks a lot.
RE: Equilibrium curve for butane-propane
you have access to a process simulation software? i don't think there is a single one out there which is unable to calculate VLE. especially for a mixture of propane and butane (n-butane, i presume), which has no particularities whatsoever.
yes i have access to a process simulation software called ASPEN, but it is not able to calculate VLE, it can only run a process which is predefined.
My email adress : dahbia.bioud@polymtl.ca
Thanks Phex.
hth, chris
