Toggle model screen color
I used to have a routine that toggled the model screen  color from black to white. It was written in VLISP, but I cannot find it anymore. I used it for saving rendered or hidden images with a white background, then I would toggle the screen back to black. Does anyone have this routine or one similar to it?
Flores
RE: Toggle model screen color
Found this at the bottom of: http://www.vbdesign.net/expresso/archive/topic/840.html
;;Background color changer
;;Gary Maze, SMC Corporation of America
;;11/27/02
;;acadobject is the ActiveX component of the AutoCad instance
;;acadpref is the preferences property of acadobject
;;acaddisp is the display propertis of acadpref
;;the background color is the windows color number calculated by the following formula;
;;(65536*blue)+(256*green)+red, where blue, green and red can be 0 (off) to 255 (all the way on)
;;Whiteback makes a whitebackground with a black crosshair
(defun c:whiteback ()
(setq acadobject (vlax-get-acad-object))
(setq acadpref (vlax-get-property acadobject 'preferences))
_(setq acaddisp (vlax-get-property acadpref 'display))
_ _ _(vlax-put-property acaddisp 'GraphicsWinmodelBackgrndColor 16777215)
_ _ _(vlax-put-property acaddisp 'modelcrosshaircolor 0)
;;Blackback makes a black background and a green crosshair (my personal fave-rave)
(defun c:blackback (/ acadobject acadpref acaddisp)
_(setq acadobject (vlax-get-acad-object))
_(setq acadpref (vlax-get-property acadobject 'preferences))
_ (vlax-put-property acaddisp 'graphicswinmodelbackgrndcolor 0)
_ (vlax-put-property acaddisp 'modelcrosshaircolor 65280)
_)
The user just wanted to change his background color to white, but I thought it might be nice to add a restore function as well.
Several other programming efforts at changing colors there too.
Thanks Starry, that worked great!  I changed the following part in the "blackback" routine:
to read:
_ (vlax-put-property acaddisp 'modelcrosshaircolor 16777215)
so that I would have a white crosshair with a black screen instead of a green crosshair.
Flores
