CAM PROBLEM??????
CAM PROBLEM??????
Hi. I begin using a CAM software, but when I generate the G-code, there are some instrucction the no run in the CNC machine. So I must correct the G code manually.
Is this a comun problem????
What can I do?
Any help I'll apreciate.
What can I do?
RE: CAM PROBLEM??????
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
I configure the post processor but the problem is the same.
What G codes are being put into the file that your control doesn't like?
What machine control are you programming for?
Ben Loosli
Ingersoll-Rand
T02 M06. I mus change the order of the instruction to M06 T02 (if I want to use #2 tool)
