spent caustic
spent caustic
Hi:
There is someone who has some information about systems to treat spent caustics from oil refineries.
RE: spent caustic
Regards, Alfredo Cruz
email:alfredo.e.cruz@exxonmobil.com
RE: spent caustic
I can only help you if there is a definite enquiry for this plant. I would require the following information:
1. Feed analysis (Na2S, NaHS, NaOH, Phenol or Sodium Phenate, Ammonia, Chlorides, DSO/Disulfide Oil, Na2S2O3, Cryselic Acid or Sodium Cryselate, Napthenic Acid or Sodium Napthenate).
2. Required throughput.
3. Effluent specification (COD, BOD, Na2S2O3, DSO,Organics).
4. Steam supply (>= 200 C) conditions.
5. RFQ to allow the vendor to quote.
6. Refinery name and contact details.
7. Availability of > 96 % w/w sulfuric acid from local suppliers.
8. Any kraft paper production plants within 150km distance of refinery.
We would be able to supply the complete plant (skid or stick built) or alternatively provide a Schedule A Detailed Engineering Package which would allow the refinery to utilize a fabricator of its own choice in the country where the refinery is located.
You can get hold of me at: courtneydehn@canada.com while I am out of Canada (will return mid December).
Courtney Dehn
Process Manager
TG Engineering Inc.
Calgary
Alberta
Canada
