Equations in Assemblies
Has anybody found a way to use equations
in an assembly or can they only be used
for parts?
for parts?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Equations in Assemblies
MadMango
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
I wouldn't suggest using equations tho. Instead use reference geometry. Either create a sketch in your assembly and/or create planes and axes to reference to. Or more preferrably put that reference geometry in a separate stand alone part file. We usually call that part the "Layout Sketch". Then you can put that part file in any assemblies that share common features, with the goal (hopefully) not have to have so many assemblies open or a single large assembly...at least that's the idea behind it ;0)
Ken
