filleting in surfcam
I started using surfcam 2000 surface modeller to model castings just over 15 days ago. my problem is when i am done with all the modelling, i cannot fillet those surfaces and trim them up. does any one know how to fillet and trim surfaces ? for example, when you are modelling a vane that comes out of a surface and you try to fillet one side of the surface with the vane, it cuts away the rest of the surface too which is not desirable.
i hope the reader understands my question.
thanks
