A 516 Gr. 60
A 516 Gr. 60
wich is the temperature range of the A 516 Gr.60 steel?
Can I use it for -10°C=>70°C air-pressure vassels (10bar/diameter 10inch)?
We would like to PED-certify our item. I know that I have to ask to my supplier:
- EN 10204 3.1.b certify
- a Quality System
- WPS for weldings
The question: do I have to ask my supplier for additional requirements such as:
1) Iso V Notch Impact test at -10 °C
2) High temperature (70°C) tensile tests??
Carlo - Italy
- a Quality System
- WPS for weldings
Carlo - Italy
RE: A 516 Gr. 60
According to ASTM A 20 the material A 516 Gr. 60 can easaly fullfil this requirement. Actual impact testing would not be required.
Hot tensile testing is not required.
RE: A 516 Gr. 60
"According to ASTM A 20" ... you can suppose my next question ... can I find on the web the ASTM A 20 (or a part of it, to make evidence about your considerations).
carlo
cmontagnani@aeautel.it
RE: A 516 Gr. 60
http://www.astm.org
Cory
RE: A 516 Gr. 60
Similarly tensile test at 70 degree is not necessary. Refer to ASME sec II D + UCS 23 table, the allowable stress of the material you have specified does not vary, and 70 degree centigrade is not considered high temp.
As regrads Standard WPS as permitted in ASME Sec VIII UW would do (You may also have to refer AWS D 1.1) if you do not want to do fresh PQT.
