Spinning Model
Spinning Model
After creating/modifying/redefining a feature the model then spins out to a defined position, I then have to zoom/spin back in to the area where the feature is to check to see if is ok.
Is there a config pro option setting to stop this or at least reduce it.
Thanks in advance
Thanks in advance
RE: Spinning Model
I too have the same problem and I'll get back the orientation by VIEW >> PREVIOUS Option.
So that I get the previous orientation before modifying.
So far I too didn't get any config option for that. If you get an option for that Please mail me.
Hope this will Help you a bit.
Cheers
Balaji Gopinath K.
RE: Spinning Model
ProEpro
www.whitelightdesign.com
RE: Spinning Model
