HP 48/49 and COGO
HP 48/49 and COGO
I’m thinking about buying a basic COGO package to use with a HP calculator.
I see that there are a lot on the Internet for the HP 48G series. However this calculator is discontinued and the HP 49’s are out. I don't have a HP48.
Will a GOGO program written for a HP48 work in a HP49? Will I need an emulation program to mimic the HP48 operating system in a HP49?
Are there any COGO packages available for a HP49?
I have a Sokkia Set 5B total station. (I know a little old but it’s all I need.) Are there interface cards available for between the total station and the HP49? Will a HP48 cable work?
If I use a HP49 are there environmental cases for the calculator?
Any advise and guidance in this area will be appreciated.
Rick Kitson MBA P.Eng
Construction Project Management
From conception to completion
www.kitsonengineering.com
RE: HP 48/49 and COGO
Quickest way to an answer is to ring your local Sokkia rep and ask for what you require. I know some sales reps can be a pain but at least if you go ahead and purchase cables and the like and they don't work you can go back to them.
I know when I was using a Sokkia set 5 a few years ago it would interface with the HP48 and I would imagine that Sokkia would keep a certain level of compatibility about their gear to include updates for HP connectivity.
Good luck
sc
