Properly ending a Macro
I know I brought this up before, but I was wondering if anyone has run into this. After I run a macro, it stays in memory and doesnt 'end' properly which leads to it crashing if I run too many macros in a row. Any comments? Thanks in advance.
RE: Properly ending a Macro
1. Open "Task Manager" and click "Performance" tab.
2. Record a value at "Total" under "Commit Charge (K)
3. Run a macro and notice "Total" goes up.
4. Close the macro and "Total" should go back to the previous.
As long as a macro releases the memory usage each time, it's up to total memory you have how many macro (program) you can run.
I am not an expert of Macro, but this is a simplest one.
Sub main()
Set swApp = Application.SldWorks
Set Part = swApp.ActiveDoc
End Sub
It doesn't do anything, but it goes out from the memory. Even if a macro is terminated by "Cancel" it will release memory by hitting "End" when you get "Run-time error".
Make sure if your macro releases the memory first.
Give this a try in your exit button.
Private Sub cmdExit_Click()
Set swApp = Nothing
Unload Me
End
End Sub
Bradley
I just tried that with no success. Is 'Unload Me' a general statement or does it require a parameter?
I believe it is a general statement. My Visual Basic teacher, a few years ago required us to put this in every VB program we gave him. He said it removed the program from memory.
Bradley
This is from VB help.
Note The End statement stops code execution abruptly, without invoking the Unload, QueryUnload, or Terminate event, or any other Visual Basic code. Code you have placed in the Unload, QueryUnload, and Terminate events of forms and class modules is not executed. Objects created from class modules are destroyed, files opened using the Open statement are closed, and memory used by your program is freed. Object references held by other programs are invalidated.
The End statement provides a way to force your program to halt. For normal termination of a Visual Basic program, you should unload all forms. Your program closes as soon as there are no other programs holding references to objects created from your public class modules and no code executing.
The following example assumes two UserForms in a program. In UserForm1's Initialize event, UserForm2 is loaded and shown. When the user clicks UserForm2, it is unloaded and UserForm1 appears. When UserForm1 is clicked, it is unloaded in turn.
' This is the Initialize event procedure for UserForm1
Private Sub UserForm_Initialize()
Load UserForm2
UserForm2.Show
End Sub
' This is the Click event for UserForm2
Private Sub UserForm_Click()
Unload UserForm2
End Sub
' This is the Click event for UserForm1
Unload UserForm1
End Sub
Step thru your routines and find any 'set Object =' type statements that do not have matching 'set Object = nothing' statements. Just because the object was created locally in a sub/function does not (necessarily) mean it does not still exist, Objects are treated a little differently.
Also Make sure to check that any objects created in a sub are set to nothing before a premature exit:
Sub Test
Dim MyDoc as ModelDoc2
Dim FeatMgr as Featuremanager
Set MyDoc = swapp.ActiveDoc
Set FeatMgr = MyDoc.Featuremanager
if FeatMgr is nothing then
Set MyDoc = nothing ' gotta add these too!
Set FeatMgr = nothing ' so objects are cleared!
Exit Sub
end if
Set MyDoc = nothing ' most ppl will add these at end
Set FeatMgr = nothing ' of routine for housekeeping
end sub
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim longstatus As Long
Dim Annotation As Object
Dim Gtol As Object
Dim DatumTag As Object
Dim FeatureData As Object
Dim retval As Variant
Dim Error1 As Variant
Dim success As Variant
Dim Feature As Object
Dim WorkingDirectory As String
Dim Component As Object
Sub main()
WorkingDirectory = "\\Wal7\Adept\Integration\SolidWorks\SW_Adept.dll"
retval = swApp.LoadAddIn(WorkingDirectory)
If retval = -1 Then
Error1 = MsgBox("The filepath name is wrong, check to see if it has changed", vbExclamation, "Adept Macro")
End
End If
If retval = 2 Then
swApp.UnloadAddIn (WorkingDirectory)
End If
End Sub
I have tried to unload me, set everything to nothing, but it still remains in memory. I am thinking that it is a problem with the VBA editor with SolidWorks. Any commets?
Too be honest, your program needs a bit of work. For a start, you should declare all your variables inside a subroutine or function to limit their scope. Declaring variables at the module level should only be used if you REALLY need another sub/function/userform to access the variable. Use the Option Explicit statement to stop VB creating variables without you knowing about them. You're also using way too many variants. Variants are evil and should be avoided at all costs. They allow people to write really bad code, which can end up producing very obscure errors. Finally, you aren't checking all the return values for the loadaddin and unloadaddin functions.
I have to question the necessity of loading and unloading an addin programatically. If you need to use it all the time, then just leave it loaded all the time. Anyway, I've modified your code to load and unload PhotoWorks. It seems to work fine on my computer. You should be able to modify it to do want you want.
Option Explicit
Sub main()
Dim swApp As Object
WorkingDirectory = "C:\Program Files\SolidWorks\photoworks\pworks.dll"
Select Case swApp.LoadAddIn(WorkingDirectory)
Case -1
MsgBox "Addin not loaded. Error generated"
Case 0
MsgBox "Addin loaded"
Case 1
MsgBox "Addin not loaded"
Case 2
Select Case swApp.UnloadAddIn(WorkingDirectory)
Case 0
MsgBox "Addin unloaded"
Case 1
MsgBox "Addin not unloaded"
End Select
End Select
End Sub
PS: Using 'unload' for objects is generally considered good form, but is often not that necessary. When a sub terminates, it will release all the memory allocated for it. There are a few instances where 'unload' should be used IMO, databases are a prime example.
think that was a really bad example to give. My programming skills are not ideal by any means, I am learning as I go along. If I want to simply have a userform load and then close it out, it is still left in memory no matter if I set the objects to nothing or not. Maybe I need to take a step back from this macro trouble and go back to basics. If I have two objects and 3 variables, do I need to specifically say:
Set Object1 = Nothing
Set Object2 = Nothing
Set Var1 = Nothing
Set Var2 = Nothing
etc...
All I want is for the program to close out and clear all variables, objects, etc. so that it is no longer in memory and interfering with other tasks. Maybe that is a better way to define the problem.
Userforms are a bit different from objects declared at the subroutine level. The most common way to get rid of them is to use the unload(userform_name) function. This will completely remove the userform from the memory and return control to the calling subroutine.
>>set swApp = nothing. In fact, I hardly ever do it. There
>>are very few instances where you do need to do this.
>>It's not the big problem everyone else has made it out to
>>be.
Not if you're only running apps with a few hundred lines of code. You start activating multiple applications, recursing thru objects, etc, and you'll find it as necessary as "Option Explicit". Besides, it's like praying: what have you got to lose?
