Vessel Support Design on 3 Saddles
Hi
I'm looking for proper design of a horizontal tank on 3 saddle supports. I'm familiar w/ LP Zick Analysis but that only gives design for two supports. Any help appreciated
ipseng
ipseng
RE: Vessel Support Design on 3 Saddles
K. p. Singh "An approximate analysis of fondation stresses in horizontal pressure vessels" ASME PUBLICATION PAPER NO. 79-NE-1, 1979
Q's:
using the continuous beam theory ie) from AISC ASD Beam Design Formulas(pg.2-312) would you use the uniform load with 3 supports and add the overhang load to the outer ones and then tack on the 20-50% of result? Is there a simplified version to these support reactions? I can't seem to find any loading diagrams for this specific case.
Any ideas?
see if you can find the following articles.
call Holtec International
609.797.0900
ask them to send you a copy of this paper:
"An Approximate Analysis of Foundation Stresses in Horizontal Pressure Vessels", (with Vincent Luk), Paper No. 79-NE-1, Trans. ASME, Journal of Engineering for Power, Vol. 102, No. 3, pp 555-557, July, 1980.
