Dangling drawing dimensions
When I detail my models on a drawing I use driven dimensions (manually inserted similar to AutoCAD). When the model changes and the drawing is updated, dimensions are left dangling on the drawing. Ordinate dimensions can be re-attached to model features by dragging the dimension to the new feature but linear dimensions don't seem to allow this. I end up deleting all dangling linear dimensions and re-creating them (losing any tolerances and GD&T in the process). Is there a way to "drag and drop" dangling linear dimensions onto new features?
SW 2003 SP 5.0
killswitch
RE: Dangling drawing dimensions
Sounds like you are changing the model's configuration or something. Perhaps an example would be you dimension a block, and then add a cut that makes the edge disappear or changes somehow. Doesn't make a lot of sense, but is your model just changing size, or are the edges being altered somehow?
Mr. Pickles
If a feature is removed and replaced with another during a model revision, dangling ordinate dims from the original feature can be dragged and attached to the new feature and become driven.
The same cannot be done with dangling linear dimensions. The only thing I can do is delete them. If the new feature needs to have similar tolerances and GD&T as the old one, it makes sense to me to "re-cycle" the dangling dimensions and have the value of the dimension reflect the new feature it's attached to.
killswitch
Put that on my wishlist, too.  In model sketches, some dimensions can be reattached, but not in drawings.
Dimensions "remember" the name of the entity to which they are attached.  As long as you are only modifying that entity, the dimension will remain attached.  If you delete the entity (feature) and replace it with a new one, then the dimension won't find its entity.
If the ladies don't find you handsome, they should at least find you handy.
Keep putting in those Enhancement requests for this. I have been asking for that... for about 5 years now. If you don't put in the requests then you won't see this ever get done.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
I also noticed that, when it comes to detached dimensions in sketches, some can be reattached while some resist all attempts at reattachment.  Also true for some constraints.  This is usually when the dimension was attached to a model edge.
