AutoCad 2002 query
AutoCad 2002 query
AutoCad 2002 query
Hi all,
Whilst using AutoCad 2002,if i select from the dimension toolbar either angular,radius or diameter and then select the item i am trying to dimension, autocad just immediately shuts down all other dimesion buttons are working fine.
Can anyone offer an exsplanation to why this is occuring and hopefully a solution.
Best Regards
marty.
RE: AutoCad 2002 query
You might want to post this in the Autodesk:Autocad forum for a wider audience that actually uses Autocad.
Flores
I am a little confused w/ your two last lines of your first paragraph. Can you restate what you mean?
