Carbon Dioxide specific gravity at high pressure
Can any one point where I can find a tables of specific gravity for Carbon Dioxide as a function of pressure and temperature (I need this for pressure vessel calculations).
Tables for other gases such as Nirogen, Air, Helium, Argon etc. will be appreciated too.
RE: Carbon Dioxide specific gravity at high pressure
Good Luck,
Believe it or not : Had we trusted Archimedes and assigned him the work of lifting the earth(or any mass equivalent to that of earth on earth),with a lever of suitable length, it would have taken him 23 million million years to lift the earth by one centimeter, if he worked at the rate of 1 HP.
I guess he (Archimedes) would have exploited other sources of energy to move the earth at little faster, if he had to. After all he used solar radiation to burn the Roman ships, didn't he?
Costas.
The fact I stated above is not to defame the greatest mind on earth. (Even Newton considered him as a giant in science)This is just for fun. (He could have easily calculated this)
Believe it or not : Though he couldn't prove, Einstein never agreed with Heisenberg on his Uncertainty Principle.
