taper roller bearings Spacer
For creating clearance between two taper roller bearing (face to face), Shall we use spacer ring bigger/smaller than distance between two outer rings of bearings?
For example if we have 35mm distance between two outer rings, shall we use 35.05mm or 34.95mm spacer ring??
RE: taper roller bearings Spacer
i mean parctically in assembly.
When I have to separate these further with a supplemental spacer, I just manufacture a cup spacer and cone spacer of the same length and don't worry about it because the supplied cup and cone spacer are still used.
It is important for the rolling elements of the cone to be in contact with rolling surface of the cup.
I would suggest contacting the bearing manufacturer and explaining your assembly to them and follow their recommendations.
Neville French
Elstree UK
