Plate with a bore
Plate with a bore
A plate (A105) with a tappered bore (1/2") is to be installed between a pair of flanges (B16.5).
The logical thing is to use a plate with a thickness equal to the orifice flange's for the corresponding pressure class and diameter. And then make the bore to the required size.
Is there any reference to use for the calculations of this plate thickness?
RE: Plate with a bore
John
