Friction Welding Service
Looking for a possible friction welding contractor in the Houston area - any leads?
RE: Friction Welding Service
I haven't heard of one in Houston. You would think there would be with all the work around there. I did have one that was in Louisiana but the link is dead.  The two that I’m familiar with are
American Friction Welding Inc and Spinweld Inc.  I know American is in Wisconsin and think Spinweld is also.
They were quite a few people in it a one time but I haven’t seen much activity other than seeing a few parts that have been friction welded.
Here is website with locator service.
http://www.frictionwelding.com/ffwprov.htm
MTI in South Bend, IN is another manufacturer with contract services available.  They may be able to provide you with a lead on a customer in TX:
http://www.mtiwelding.com/
Carburize,
Please see the FAQ Internet Resources on FSW (FAQ725-478). There is a lot of good information to search through.
Best regards,
Matthew Ian Loew
"Luck is the residue of design."
Branch Rickey
Thanks "MLoew" however, I am not interested in FSW I just need a local source for conventional FW of cylindrical sections.
Carburize,
OK, I was hoping that you could use the resources for FSW to use in searching for cylindrical Friction welding as well. Here is what I was able to find:
Here are some additional vendors you may wish to contact, including one in Texas:
Drill Pipe Industries, Inc. Texarkana, TX
:(www.drillpipeindustries.com)
American Friction Welding, Inc. Brookfield , WI (www.teamafw.com)
Spinweld, Inc. Milwaukee , WI (www.spinweld.com)
ARD Industries Ltd. Cambridge , ON (www.ardindustries.com)
NCT Friction Welding Newington , CT (www.nctfrictionwelding.com)
Interface Welding Carson, CA (www.interfacewelding.com)
Inertia Friction Welding South Bend , IN (www.ifweld.com)
Manufacturing Technology, Inc. South Bend , IN (www.mti.com)
I found these mostly through Thomas Register (www.thomasregister.com) and by Googling.
Best regards,
Matthew Ian Loew
Branch Rickey
Thanks MLoew - I will check out the Texarkana location
