Revision table
Revision table
Hey-Is there a way to modify the Revision table in 04. I’m trying to set up two custom tables, one for Pre-Production Started with “XA” (then XB…) and Second for production started with “– “ (then A…). I’ve tried modifying and saving templates but I’m not having much luck. I don’t understand how the default template is made, so if someone has messed with this and knows more I’d appreciate any info
RE: Revision table
You could have a seperate drawing template for numbers and another for letters if one didn't want to switch, but that isn't your problem.
I would think you are stuck to fixing it manually. If you insert the revision table, and all the revision triangles (or whatever) for that revision, you can change the rev indicator in the table and all the triangels will change.
Otherwise, I'm lost too....
Mr. Pickles
RE: Revision table
FYI...per drafting stds, dwgs should be numerical for preliminary (engnieering build) then go to alpha (starting with "A" (production build).
