Flash programming
Flash programming
Flash programming
Could anyone direct me to information for beginners in flash programming or give me some samples of code. I searched on the net, but I could not find anything.
Cheers
RE: Flash programming
Look in the flash data sheets / application notes.  They tell you everything that you need to know!  The code is fairly trivial to do exactly what they say (sending the correct bits, in the correct sequence).
