does anyone know how to calculate d
does anyone know how to calculate depth and capacity of stone columns in short time??
hubtom
hubtom
RE: does anyone know how to calculate d
A lot depends upon the type of method you may adopt for the stone column construction. If it is a displacement method, then a method based on earth pressure or the cavity expansion method may be suitable. Alternatively, if it is replacement method of construction, then you could look into something like the Japanese method (settlement reduction ratio, etc.).
Can you tell me where I can find something more about Jananese method??
I want to know how calculated stone columns done with using vibro.
BR
hubtom
You could get meaningful references from the paper in Geotechnical Testing Journal:
Title: Effects of Installation Method on Sand Compaction Piles in Clay in the Centirfuge
Volume: 24
Issue: 3
Year: 2001
