Data to manufacture a helical gear
Is there a spec or a standard to spec out the manufacturing data for a set of helical gears?
I can't find one and I can't anyone who knows.
jackboot
jackboot
RE: Data to manufacture a helical gear
diametral pitch (or module)
helix angle
hand
normal pressure angle
normal circular tooth thickness
outside diameter
root diameter
normal fillet radius
normal tip radius
these are the minimum callouts you need to define the helical gear geometry completely. Any other specs may be of use for measurement.
