What Centrifugal Pump for Fruit Juice?
3
Dear pumpexperts,
What kind of centrifugal pump do you recommend for fruit juice pumping? What are the major things to consider?
Application details:
Flow: 10 - 40 m3/hr
Concentration of fibres: 1% (fibres about 1 mm)
Temperature: 60 - 95 gradC
One of our main concerns is how to avoid blocking with fibres.
Many thanks for thinking with me,
MVD
RE: What Centrifugal Pump for Fruit Juice?
hi mvd,
the major thing is cleanabiliy of the pump. That is why you need an "open impeller"(dont know if this is the right english expression). with this solution you also have no problems with blocking. if you are still afraid, use a small filter before the pump to be shure, that the particles are this size.
in many cases the juice producers use things like aktive carbon or bentonite. these things are very abressive.
last but not least all materials must be suitable for food and the cleaning caustic.
ciao apfelsaft
Do you know any manufactures, types with "open impellors" ?
Thanks !
Does it have to be centfrifugal? I would suggest ( at the risk of others saying you have to do further analysis)a progressive cavity pump- they should be able to handle the'fibers'& have flow rates up to 130 m3/hr- for info look at www.seeepex.com ( I use them , don't sell them) -they have pumps for the food industry that are FDA approved-just want you to consider them while you look for pumps
MVD,
The "pumpschool" wesite suggests a lobe type, positive displacement rotary pump for fruit juice service..
   www.pumpschool.com/principles/lobe.htm
The comments made above about "cleanabilty" are very important...
Some people use air-operated diaphragm pumps (AOD) pumps for the fiber laden juice
See    www.ubd.co.nz/company-profiles/206734046/
Hope that this helps....
MJC
Hi all,
We will go for centrifugal pump because we het good results on some trials and they are cheaper. Now we want the best of this pump-type.
NB. The fluid is just like juice almost water-like.
Thanks all,
MVD
to stay on the subject of "why not a progressive pump" i would like to add that a centrifugal pump can be a pain to clean especially if there are some solids in the juice because these may stick to the casing.
In favour of e.g. progressive pumps is that they "clean themself" (not absolutely true but solids dont stick).
I dont think they are especially expensive compared to good centrifugal pumps - and they are very easy with frequency control.
I have personally good experience with Seepex (allthough this was for an oil&gas application)
Best regards
Morten
hi all,
two centrifugal pump supliers with experience in the juice industry i know are:
www.hilge.de
www.fristam.com
i personal prefer hilge, if its posible working without abressive materials.
ciao apfelsaft
I'm not sure 1% of 1mm in length is much of a sweat for any decent centrifugal pump, enclosed, semi-open or otherwise.  It all depends on the impeller geometry.  And with 40-180 gpm, your typical small centrifugal pump should have enough clearance between the vanes to prevent any appreciable clogging.
Generally speaking the mechanical seal would be ok as well, since centrifugal force would tend to pull the "solids" away (if the box is open or bell housing type.
However, if your in the juice industry, you want FDA approved materials.  There are plastics that are approved (Noryl for example), but most everyone will use stamped stainless.
Also, peristaltic pumps are used in the orange juice dispensers.......
Thanks all,
We will go for this pump, very nice impeller design:
Tuchenhagen - VARIFLOW Centrifugal Pumps, Series KN und TP
The pump series KN und TP have been developed in order to meet today's requirements of cleanability, gentle product handling, efficiency and easy maintenance. Six pump sizes are available with flow rates up to 140 m³/h and flow heads up to approx. 100 m w.c.
http://www.tuchenhagen.com/eng/index.html
No shares ; )
M.
