Applicable Hydraulic Steel Structure design codes
What Codes are used in the design of Hydraulic steel structures?  We are currently using the DIN 19704/5 of 1976.  Is there perhaps a newer version or other equivalent standard or code?
RE: Applicable Hydraulic Steel Structure design codes
Hi Conunndrum,
We are using the same code issued the same year. I have no hear of newer versions.
Ajose
It seems that their is a newer version (1998):
DIN 19704: Part 1 Criteria for design and calculation
DIN 19704: Part 2 Design and manufacturing
DIN 19704: Part 3 Electrical equipment
